SQL 2005 Express Backup
Man of Honour
17 Nov 2003
Southampton, UK
What I want to do is backup an SQL 2005 Express DB to the harddrive.
However, I need it to be an unattended and be done on daily basis with a unique name (possibly a datestamp?)
How do I do this? MS have changed everything from SQL 2000 which i'm used to.
Burnsy
have tried going into SQL Management Studio, expanding databases, right click the database you want to back up, goto tasks and then select backup?
pretty sure you can backup the db to a single bak file.
Thanks, that exaclty what I want to do except I want it to run it automatically everyday. Any ideas on automation?
Burnsy
Burnsy
unfortuantly not, as said before if you want automation you need somthing like Backupexec, but that won't back your database up as single files :(
The thing is, I know is SQL 2000 you could schedule a file backup at a certain time, surely you could still do that in 2005?
Burnsy
