Sql - adding top 100 percent speeds up query many times
Caporegime
13 Jan 2010
Llaneirwg
Never seen this before.
I have a query, where I am join it back onto itself with a different subset each time using a where
So
Select
From
(select * from t
Where x
Inner join
(select * from t
Where y
On conditions
Etc
4 join. Conditions present
Adding top 100 pc to each sub query speeds the query up many times over.
It makes no sense to me.
Any ideas?
How many rows in the table t?
Assuming T has > 100 rows - Limiting rows on the subset massively reduces the data that needs to be held in memory/temp space and also reduces the complexity of the resulting looking. Being nested multiple times
Why do you need 3 layer nested subqueries to achieve this? There is almost certainly a better way! Share some more context, schema/table design etc and can probably guide on this.
Sam
(SQL developer and DBA for a long time)
