SQL and Access Help
19 Jul 2006
Leicester
I have no past experience with Microsoft Access, and as my University Course is doing the Module "Database Design Concepts" I think SQL will be involved somewhere.
Basically, I have built a very simple Database with called "Practice" it only has one column in it with the name "Name" then a list like this...
Steve
Andy
Ant
John
I now want to executed (I think is the correct term?) this SQL statement...
SELECT Name FROM Practice
The problem is, I don't know where to executed this statement!!!
On this webpage... http://www.w3schools.com/sql/sql_tryit.asp (about half way down) they have a little box to execute the SQL statements.
So could someone please tell me where to execute my SQL statements, in order to extract information from my Database.
Thank you so much :D Steve
You'll need to install Oracle on your PC/laptop, which i was told not to do, so i just use the machines at uni that have it installed.
Have you tried making the table in access, and using the SQL view?
MS Access is the devil's financial advisor, don't use it! MS SQL Express with Management Studio Express has a better, friendlier and more powerful GUI.
Thanks for the replies :)
I have my 1st Database Desgin Concepts lesson at 11am, so I will see what happens and I'l get back to you :)
