SQL and VS Code
Caporegime
25 Jul 2003
FR+UK
I'm a long time SSMS user but more out of necessity, and I really really want to ditch it. I'm using VSCode for almost everything else, and I want to try and move over to it full time for SQL. I've got a few handy plugins (code beautifier, debugger) but I'm struggling to replicate the Object Explorer. Using the MS SQL plugin I can set up connections, but it unless I'm doing something wrong, it seems to be on a per database level, rather than server, and as I work with many databases I don't really want to have to set up a new connection for every database. Is there a decent connection manager I'm yet to find?
I ditched SSMS a few years back and have been using Azure Data Studio instead. Despite the name, you can use it to connect to a DBMS hosted anywhere (some NoSQL/docDB implementations require extensions).
Annoyingly though, MS are dropping support for it and integrating it directly in to VSCode, so in theory if you're already using VSCode then you can just install the MSSQL extension and have access to ADS features within your IDE. More details on that here: https://learn.microsoft.com/en-us/azure-data-studio/whats-happening-azure-data-studio#migration-plan
Aye I read that the other day whilst on the hunt around, but that has the same problem as the lack of an Object Explorer.
I don't think object explorer is a plus. I recommend dapper and write your SQL in ssms. This is how we work and it's the standard in a number of large companies I've worked for.
For dev, sure. You need an object explorer when trying to optimise queries, or looking at execution plans, or doing security reviews etc.
And they still haven't added backing up Azure DBs to VScode yet so don't even have feature parity yet
I've only stopped using DBeaver beacuse I struggled to get it to connect to my local SQL instance under my employer's weird security setup. I miss it.
Keen to try Azure Data Studio...
I was a big fan of Navicat a few years ago when I was “databasing” on a daily basis. Nowadays I use Datagrip which is very decent!
SSMS is the best. VSCode SQL extension is pants.
The newer prerelease of ssms (21)is ok, more modern Visual Studio shell… but I still prefer the supported older styles one (20), just works better.
Recently moved from SSMS 18 to SSMS 22.. and I prefer it now.. which is surprising as usually MS make things worse over time..
