SQL Applications...
12 Jun 2003
Either Tonbridge or Biggin Hill
Hi all,
Just curious to see what applications you use to maintain your SQL databases at work (or at home!)
I use a combination of SQL Advantage and Sybase PowerBuilder. I've only just started learning the basics so Advantage is ideal for simple SELECTs & UPDATEs.
If anyone knows of any good online SQL guides that would be good too.... :)
Hi Mate,
You will probably best asking this in HTML, Graphics & Programming.
Cheers,
TrUz
What exactly do you mean by 'maintain your SQL databases'?
We use Oracle 9i at work and use a combination of SQL*Plus and TOAD to do development and administration.
I'm currently in the process of getting 10g R2 set up on a Linux box at home.
Code:
root@abox [~]# mysql
Welcome to the MySQL monitor.  Commands end with ; or \g.
mysql>
:p :D
But also MySQL Administrator and phpmyadmin.
I use SQL Enterprise Manager mainly for quick queries / maintenance stuff, sometimes Query Analyser for testing stored procs / larger queries, on MS SQL 2000 databases.
Hi,
I use Ingres at work and home. To run SQL I normally put the SQL into scripts and run these so they can be repeated. For one off pieces of SQL I use the supplied command line tools (ISQL and QBF).
I do front-end development using OpenROAD (a 4GL quite similar to PowerBuilder but which is showing it's age somewhat), Perl/Tk and Java.
Jim
I've replaced this at work with SQL Server Management Studio (SQL 2005) - 'tis like Query Analyser and Enterprise Manager, but in one handy package. Much better IMO.
At home I use the Express Edition of SQL Server and Management Studio
pjt@stimpy:/home/pjt/>sqlplus username/password@sid
SQL*Plus: Release 8.0.6.0.0 - Production on Tue Jun 6 09:06:59 2006
(c) Copyright 1999 Oracle Corporation. All rights reserved.
Connected to:
Oracle8i Enterprise Edition Release 8.1.7.4.1 - Production
JServer Release 8.1.7.4.1 - Production
SQL>
