- 31 Dec 2003
- Barrow-In-Furness
Is there anyway of putting a prefix on an primary key field? I'll try explain with an example.
tblCodes
CodeID [PK] - Integer
CodeName
CodeDesc
CodeType
When a new code is created the ID is simply the next value as you would expect. To help with identifying the codes in my actual application, I would like the ID to be based on the CodeType.
For example: There are four types of code (red, green, blue, orange), if when creating a new code the user selects the type red, the CodeID will be "RED\1". If another is made using the type red, it will become "RED\2". The same applied the the others, a green code will have a prefix of "GREEN\" which increments.
Really not sure how to go about doing this, maybe a seperate table for CodeTypes is needed? I'm a novice programmer and i'm also new to SQL to please to be gentle!
Thanks for any help.
tblCodes
CodeName
CodeDesc
CodeType
