SQL - Calculations on Alias Columns
~J~
~J~
20 Oct 2003
London
Anyone have any ideas what I'm doing wrong here:
SELECT dbo.Comparison.seq,
dbo.Comparison.Material,
dbo.Comparison.MaterialType,
dbo.Comparison.MaterialDescription,
dbo.Comparison.MRPController,
dbo.Comparison.Rounding,
dbo.Comparison.Cost,
SUM(dbo.InventoryCheck.PlantStockAvailable) AS 'R3Stock',
0 as 'Physical',
R3Stock - Physical AS Diff
FROM dbo.Comparison
INNER JOIN dbo.InventoryCheck
ON dbo.Comparison.Material = dbo.InventoryCheck.MaterialCode
GROUP BY dbo.Comparison.seq,
dbo.Comparison.Rounding, dbo.Comparison.Cost
HAVING (dbo.Comparison.Material = N'EU-E35-11710A')
The error I get is that there is no column(s) called "R3Stock" and "Physical", which I know there isn't but I've created them as alias columns.
Any ideas how I can get the calculation of the two alias columns?
(btw: I know 'Physical' is zero at the moment)
Just do SUM(dbo.InventoryCheck.PlantStockAvailable) - 0 AS Diff
Yes, you will have to change it if your R3Stock or Physical columns change their formulas but AFAIK that's the only way to do it.
Yeah you're right. Cheers for that. The only other option I thought of (seeing as there are going to be about another 10 columns based on calculations from the first 2) is to insert into a temporary table (whcih would then have column names and not aliases) and do the calculations there.
Cheers anyway.
