SQL code check
Permabanned
9 Apr 2006
Can someone check this code is correct please. It doesnt seem to work for me, i think ive missed something out.
Code:
UPDATE phpbb_config SET config_name = 'portal_version', config_value = '0.3.B9', is_dynamic = 0 WHERE CONVERT(`phpbb_config`.`config_name` USING utf8) = 'portal_version';
DROP TABLE IF EXISTS phpbb_portal;
CREATE TABLE phpbb_portal (
config_name varchar(255) CHARACTER SET utf8 COLLATE utf8_bin NOT NULL default '',
config_value text CHARACTER SET utf8 COLLATE utf8_bin NOT NULL default '',
is_dynamic tinyint(1) unsigned NOT NULL default '0',
PRIMARY KEY (config_name),
KEY is_dynamic (is_dynamic)
) DEFAULT CHARSET=utf8 COLLATE=utf8_bin;
DELETE FROM `phpbb_config` WHERE CONVERT( `phpbb_config`.`config_name` USING utf8 ) = 'portal_shoutbox_b_fade_color' LIMIT 1 ;
DELETE FROM `phpbb_config` WHERE CONVERT( `phpbb_config`.`config_name` USING utf8 ) = 'portal_shoutbox_b_table_height' LIMIT 1 ;
DELETE FROM `phpbb_config` WHERE CONVERT( `phpbb_config`.`config_name` USING utf8 ) = 'portal_shoutbox_fade_color' LIMIT 1 ;
DELETE FROM `phpbb_config` WHERE CONVERT( `phpbb_config`.`config_name` USING utf8 ) = 'portal_shoutbox_table_height' LIMIT 1 ;
DELETE FROM `phpbb_config` WHERE CONVERT( `phpbb_config`.`config_name` USING utf8 ) = 'portal_shoutbox_b_height' LIMIT 1 ;
DELETE FROM `phpbb_config` WHERE CONVERT( `phpbb_config`.`config_name` USING utf8 ) = 'portal_shoutbox_height' LIMIT 1 ;
UPDATE `plusxl40`.`phpbb_config` SET `config_name` = 'portal_chatbox_number' WHERE CONVERT( `phpbb_config`.`config_name` USING utf8 ) = 'portal_shoutbox_number' LIMIT 1 ;
INSERT INTO phpbb_config (config_name, config_value, is_dynamic) VALUES ('portal_chatbox_deafault_delay', '15', 0);
INSERT INTO phpbb_config (config_name, config_value, is_dynamic) VALUES ('portal_chatbox_session_time', '300', 0);
A thank you.
Jon
