Deleted member 11679
Hello,
I have 2 tables with a column in each that I am looking to compare and filter out any that match. One table has been generated entered manually by the user, whereas the other table is a list of files from a directory that has been entered into Access through an ASP script.
Both columns contain the filename, however the filename in the column entered by the user is missing the file extension, this is held in another column in the table.
Anyway to compare the columns? The end target is to have a list of files that are currently held in a directory that have not been entered into the database, and from which can be.
If this sounds confusing I will try and explain more,
Any help would be great,
Tom
Tom
To concatenate in Access it is... + ' ' +
