SQL Consecutive Numbers
25 Feb 2007
Midlands
I have a database which looks like the following:
Category Item
Fruit Banana
Fruit Apple
Fruit Orange
Fruit Grapes
Veg Potato
Veg Carrott
Veg Lettuce
I need to give each Item in each category a consecutive number, so the above needs to look like:
Category Item Consec Num
Fruit Banana 1
Fruit Apple 2
Fruit Orange 3
Fruit Grapes 4
Veg Potato 1
Veg Carrott 2
Veg Lettuce 3
I think I need to use some sort of loop, but I can't get my head around it.
This is purely SQL, and I can't edit the database.
Can this be done? I'm using SQL Server 2005?
Cheers,
SELECT row_number() OVER (Partition BY type
ORDER BY type, item) AS num, type, item
INTO NewTable
FROM test
This assumes the Fruit/Veg column is Type and the Apple/Carrot column is item. This creates a new table, could modify into an update statement if required.
