SQL datatype for money??
18 Oct 2002
London
I started off using varchar because I could input:
29,000
But then I wanted to use this field for calculations too:
Code:
SELECT Salary, ROUND((Salary / 12),2) AS MonthlySalary
This caused an error, obviously. So I changed to decimal type (although the same seems to happen for double and int)
So now my output is like this:
29000
2416.67
Unfortunately I've lost the lovely , which separates the thousands from the hundreds....
Is there anyway to get the best of both worlds? :confused:
What are you using to get/display the output, raw SQL?
Casting the decimal back to a char or varchar won't put the comma back in so if you want to do it in SQL you'd need to cast to a varchar and then start using combinations of length(), concat() and substr() functions to break the string up and insert the comma at the appropriate point.
Or you could just chuck the data into excel and set the cell formatting appropriately.
Use an INT to store the number of pennies, then convert to pounds for display. If you use store things as a FLOAT (such as 124.45 for £124.45) you'll get rounding errors and end up losing money.
ive always been told by our DBA's to use DECIMAL(10,2) for money
not being a jedi at sql i just do what im told is best
although robs method would do the trick too
Yeah sorry I'm using mySQL. Don't you hate it when people don't tell you what they're using.....
I guess I should just create some conversion function. Although I'm not entirely fond on having to convert to pennies, maybe that's the correct way, but this isn't a 'live' app :)
Thanks guys!
