If I have system with 40 CPU cores and use SQL 2008R2 Enterprise Edition which is limited to 8 CPU cores. Can you use 8 different CPU cores for each individual SQL instance on that server, if this is the case then do I only have to license 8 cores or multiples of 8?
I know on SQL 2012 licensing you pay for cores which is not core limited, I know SQL 2012 licensing now applies to previous editions too. But under SQL2008R2 Enterprise Edition it is limited to 8 cores, so the max cores to license can only be 8, regardless of the CPUs in the system?
