SQL help (dynamic query?)
25 Feb 2007
Midlands
Hi all,
I have a database which has two tables Places and Attributes.
Attributes contains information about the place, such as number of bedrooms and number of floors, but only has two fields - attribute type and value.
This means that when I query the two tables, I get the following returned:
PlaceRef | Address | AttributeType | Value
ANY123 | 123 Any St | FLOORS | 2
ANY123 | 123 Any St | BEDS | 3
ANY123 | 123 Any St | BATHS | 2
ANY506 | 506 Any St | FLOORS | 2
ANY506 | 506 Any St | BEDS | 2
I need to normalize this so I get:
PlaceRef | Address | Floors | Beds | Baths
ANY123 | 123 Any St | 2 | 3 | 2
ANY506 | 506 Any St | 2 | 2 |
I could do this with sub selects, taking the value where the Attribute Type = 'xxx' but this would mean that I need to know each of the Attribute Types.
It would be better if I could build this dynamically so that if any Attributes are added or taken away then it automatically picks this up.
I was thinking of using a loop but not sure how I would achieve this?
Can anyone help?
Thanks,
there is a function called Pivot
http://www.tsqltutorials.com/pivot.php
which may (MAY!!) help with this
i think the query would be along the lines of
Select * from attributes
Pivot
sum(Value)
for atttributeType in (select attributetype from attributes group by attributetype)
) as p
just been reading a little more, i think the below will cover it
Dynamic PIVOT - PIVOT without specifying columns
Look up EAV structure, it will make everything more complicated but it will give you the desired result.
Its a confusing concept (possibly) at first but fits perfectly with your needs.
Pivot
sum(Value)
) as p
I'll give this a try, thanks!
From what I've read, this involves changing the DB structure. I have no control whatsoever over the makeup of the DB (its a DB used by one of our programs which I just query. Thanks for the help though.
