I have a table with the following data.
Ticket, Sequence, OldValue. NewValue, Date
1, 1, 'New', 'Closed', 07/01/2009 10:27:01
2, 2, 'New', 'In Progress', 10/01/2009 10:27:01
2, 3, 'In Progress', 'Assigned', 10/01/2009 11:45:45
2, 4, 'Assigned', 'Closed', 10/01/2009 13:32:56
3, 5, 'New', 'Assigned', 11/01/2009 08:22:23
4, 6, 'New', 'Assigned', 11/01/2009 15:44:24
4, 7, 'Assigned', 'In Progress', 12/01/2009 09:34:29
4, 8, 'In Progress', 'Resolved', 12/01/2009 13:59:49
4, 9, 'Resolved', 'Closed', 12/01/2009 14:01:22
I need to extract each record where the last entry for NewValue is 'Closed'.
Using the example above it would be tickets 1 (sequence#1), 2 (sequence#4) and 4 (sequence#9) - not 3 where the last entry is 'Assigned'.
I've tried a subquery using max which simply returns the very last record added, rather than all records where the criteria is met.
Help would be appreciated!
