Trying to knock up a query to do the following:
I've got this table with the headings
Event Table
ClientID EventNum StartDateTime EndDateTime SequenceID
and theres another table with the following:
Treatment table
ClientID Eventnum TreatStartDate Comment
Now what i'm attempting to do is this, I need to work out if there are any entries before the TreatStartDate in the event table which have an end date which overlaps an entry which was recorded after the treatment startdate.
So for the above data the treatStartDate was recorded against eventNum 6 in the event table and the end date on this is 2008-08-20 10:49:00.000
this end date overlaps the startdate of eventNum 7 which is 2008-08-20 10:48:00.000. therefore the sql query should bring back just the sequence id 3260.
heres the query i'm playing with that doesn't seem to be quite working
that seems to be bringing back the following
3260
3261
3262
3263
3268
Any ideas ?
Cheers
Event Table
Code:
T12000078 1 2007-01-02 10:00:00.000 2008-08-18 09:58:00.000 3220
T12000078 2 2008-08-15 10:37:00.000 2008-08-18 10:00:00.000 3233
T12000078 3 2008-03-18 10:04:00.000 2008-08-19 16:09:00.000 3235
T12000078 4 2008-08-19 10:09:00.000 2008-08-19 16:09:00.000 3236
T12000078 5 2008-06-05 16:15:00.000 2008-08-20 10:33:00.000 3254
T12000078 6 2008-08-20 10:35:00.000 2008-08-20 10:49:00.000 3259
T12000078 7 2008-08-20 10:48:00.000 NULL 3260
T12000078 8 2008-08-20 10:50:00.000 NULL 3261
T12000078 9 2008-08-20 10:50:00.000 NULL 3262
T12000078 10 2008-08-20 10:50:00.000 NULL 3263
T12000078 11 2008-08-20 19:55:00.000 NULL 3268
Treatment table
Code:
T12000078 6 2008-08-20 10:38:00.000 Just a test
Code:
SELECT SequenceID, StartDateTime
FROM dbo.MntClientSection mcs
WHERE mcs.StartDateTime > '2008-08-20 10:38:00.000' OR '2008-08-20 10:38:00.000' BETWEEN mcs.StartDateTime AND mcs.EndDateTime
AND mcs.StartDateTime < (SELECT max(mcs2.EndDateTime)
FROM dbo.MntClientSection mcs2
WHERE mcs2.EndDateTime < '2008-08-20 10:38:00.000' OR '2008-08-20 10:38:00.000' BETWEEN mcs2.StartDateTime AND mcs2.EndDateTime
AND mcs2.ClientID = 'T12000078'
AND mcs2.SequenceID <> mcs.SequenceID)
AND mcs.ClientID = 'T12000078'
3260
3261
3262
3263
3268
Any ideas ?
Cheers
