SQL Help
27 Sep 2004
The Ledge Beyond The Edge
Hi,
I have the following query in order to check for duplicates in a table
Code:
SELECT MAX(ID) as PONumber FROM [PurchasesTemp]
GROUP BY PONumber
Having Count(*) > 1
The problem is, if there are multiple duplicates, it only returns the last one?
Is there a way i can change it so it will return all the duplicates?
Cheers
could you do:
select ID as PONumber FROM [PurchasesTemp]
where ID = (SELECT MAX(ID) FROM [PurchasesTemp]
GROUP BY PONumber
Having Count(*) > 1)
You're going to have to show us more of the table (purchasesTemp) as there isn't enough there to work with. We need something to group by to get the duplicates.
Assuming ID is a unique key. si's code wont work either I think.
Try this
Code:
select pt.ID
from [PurchasesTemp] pt
Inner join (SELECT MAX(ID) ID1, [other]  FROM [PurchasesTemp]
               GROUP BY [other]
               Having Count([other]) > 1)  pt1
ON pt.[other] = pt1.[other]
and pt.ID < pt1.ID1
Sorry, The ID is a unique number, but what is duplicates is PONumber.
In your code, what would i use for [other]?
Surely you need to start with the list of duplicate PONumbers then find all the IDs which relate to those PONumbers:
Code:
select a.id, b.PONumber
from PurchasesTemp a
, (select PONumber, count(*) from PurchasesTemp group by PONumber having count(*) > 1) b
where a.PONumber=b.PONumber
(I'll leave you to translate from DB2 SQL to whatever you use)
I think the issue is in the SELECT MAX(ID) part. I assume that is only giving me the ID which is the highest one and not all the ID's?
[other] would be PONumber then.
In your original post you have
which aliases the ID column as "PONumber" so I thought there was only 1 column.
rpstewart's code is similar but it will show you all the rows for each duplicate, not just the duplicate rows which is what mine should do.
Code:
ID  PONUMBER
1   a
2   d
3   a
4   b
5   c
6   b
7   d
8   a
mine should give
1 (a)
3 (a)
4 (b)
2 (d)
rpstewart should give
1 (a)
3 (a)
8 (a)
4 (b)
6 (b)
2 (d)
7 (d)
Ah, yep. mine deffo won't work then.
If you only want the dup'ed rows, I'd prob do a little bit of working with a table var to work out my result set .
My code or rpstewart's will give you what you want.
if you want to remove the duplicates, use my code in a delete, if you want to display all the records that are duplicated, use rpstewart's code.
