SQL Help
18 Oct 2002
Maidenhead
Hi all,
Im trying to do a select statement. I want to return all columns, but only need the entries with the most recent effective data for each tax code. ie
Code:
TaxCode	TaxType	Rate	EffectiveDate	Cost
STD	0	17.500	1900-01-01 00:00:00.000	0.000
STD	0	15.000	2008-12-01 00:00:00.000	0.000
STD	0	15.000	2009-07-01 00:00:00.000	0.000
STD	0	15.000	2009-08-03 00:00:00.000	0.000
STD	0	17.500	2010-01-01 00:00:00.000	0.000
Should only return
Code:
I'm doing this in sql management studio 2008
Thanks in advance
If I swap order by and group by around, I get
Msg 8120, Level 16, State 1, Line 1
Column 'weighman.dbo.wmTaxSchedule.ID' is invalid in the select list because it is not contained in either an aggregate function or the GROUP BY clause.
Column 'weighman.dbo.wmTaxSchedule.TaxType' is invalid in the select list because it is not contained in either an aggregate function or the GROUP BY clause.
Column 'weighman.dbo.wmTaxSchedule.Rate' is invalid in the select list because it is not contained in either an aggregate function or the GROUP BY clause.
Column 'weighman.dbo.wmTaxSchedule.EffectiveDate' is invalid in the select list because it is not contained in either an aggregate function or the GROUP BY clause.
Column 'weighman.dbo.wmTaxSchedule.Cost' is invalid in the select list because it is not contained in either an aggregate function or the GROUP BY clause.
Column 'weighman.dbo.wmTaxSchedule.TimeStamp' is invalid in the select list because it is not contained in either an aggregate function or the GROUP BY clause.
Try:
Code:
SELECT TaxCode,	TaxType, Rate, MAX(EffectiveDate) AS ED, Cost
FROM wmTaxSchedule
GROUP BY TaxCode, TaxType, Rate, Cost
That returned
Code:
TaxCode	TaxType	Rate	ED	Cost
getting closer!
Ah yes, woops; you need to put the data that changes in to an aggregate function, sorry, so the GROUP BY clause works properly. Putting them inside a function means you can take them out of the grouping, you see.
Ahh
SELECT TaxCode, TaxType, MAX(Rate) AS Rate, MAX(EffectiveDate) AS ED, Cost
FROM [weighman].[dbo].[wmTaxSchedule]
GROUP BY TaxCode, TaxType, Cost
Would something like this work?
select * from Table a
where a.EffectiveDate = (select max(a2.EffectiveDate)
from table a2
where a2.TaxCode = a.TaxCode)
May not be syntactically correct as Notepad doesn't validate very well.
A[L]C;16174803 said:
Hi all,
Code:
Should only return
Code:
Thanks in advance
select *
from T_Tax t
where effectivedate = (select top 1 effectivedate from T_Tax t1 where t1.TaxCode = t.TaxCode order by effectivedate desc) and TaxCode = 'STD'
You really ought to have a generated primary key in there, to help identify individual rows. At the moment that works because there's only one entry per date, per type.
If each row had a unique ID, you could do the following:
select *
from T_Tax t
where id= (select top 1 id from T_Tax t1 where t1.TaxCode = t.TaxCode order by effectivedate desc) and t.TaxCode = 'STD'
select *
from T_Tax t
select *
from T_Tax t
Thats ok, but you have hard coded the tax code as 'STD'. It needs to be modified so it will report any other tax codes that might be added. So it looks like it might be a few nested sub selects to and maybe a SELECT INTO.
You've probably got plenty of replies that roughly do what you want, but my preferred choice would be the use of the DENSE RANK function. Such analytical functions can be extremely helpful in this type of situation.
i.e.
Code:
SELECT t1.TaxCode, t1.TaxType, t1.Rate, t1.EffectiveDate, t1.Cost
FROM (
  SELECT t2.TaxCode, t2.TaxType, t2.Rate, t2.EffectiveDate, t2.Cost,
  DENSE_RANK() OVER (PARTITION BY t2.TaxCode ORDER BY t2.EffectiveDate Desc) As RankCol
  FROM taxtable t2) t1
  WHERE t1.RankCol = 1
I haven't validated any of the above (too use to intellisense!), but I would recommend reviewing this type of approach even if you opt against using it in this particular situation.
hmm, that's nice, I haven't even heard of that function before!
I think I've spent too much time in nHibernate.
