SQL Help
3 Feb 2003
Sydney, Australia
Hi Guys,
I'm sure this is the most basic of basic scripts imaginable so I'm hoping someone can help.
I have a table in SQL2000 which contains e-mail addresses (about 2000 of them).
[email protected]
[email protected]
[email protected]
I need to change all of these addresses to point to a different domain but retain the front portion.
[email protected]
[email protected]
[email protected]
Is there a simple way of doing this? It's going to be a complete ball ache if I have to do them individually through the ui.
Thanks
Yup, check out the REPLACE function (MSDN)
Code:
update YourTable
set yourField = replace(yourField, 'domain1', 'domain2')
That should do the trick - I believe SQL2000 supports it
