SQL Identity
POB
POB
27 May 2003
Its a Small World
Any ideas as to why
Code:
SELECT IDENT_CURRENT('tablename')
works
Code:
SELECT SCOPE_IDENTITY()
but does not.
User SQL Express 2005 with Classic ASP.
Thanks, for looking.
The last thing prior is a very simple INSERT INTO.
I used to use the @@select identity with Access which worked fine, but up-scaling to SQL Server now.
I've checked the table and it does have a valid Identity column.
Using the following connection string:
"Driver={SQL Server};Server=(local);Database=MAS-Settings;Uid=X;Pwd=X;"
My best guess is the up scale wizard has screwed something up,
SELECT IDENT_CURRENT('tablename') - returns values based just on the table supplied for all sessions and identities.
SELECT SCOPE_IDENTITY() - this only returns values within the current scope.
This works but is there not a risk another user could have slipped a record in-between the creation the first?
I think the best solution is write a stored procedure to replace the old code.
Thanks for all the assistance though.
