SQL Insert error
28 Dec 2002
Northern Ireland
Hi Guys,
I keep getting this error in a form that is suppose to insert data into a database table. Any ideas?
Could not enter data: Column count doesn't match value count at row 1
It is being inserted into a database called team_bnlproductions and into a table called hdd_archive
PHP:
<html>
<head>
<title>Add New Record in MySQL Database</title>
</head>
<body>
<?php
if(isset($_POST['add']))
$dbhost = 'localhost';
$dbuser = '****';
$dbpass = '****';
$conn = mysql_connect($dbhost, $dbuser, $dbpass);
if(! $conn )
  die('Could not connect: ' . mysql_error());
if(! get_magic_quotes_gpc() )
   $hdd_name = addslashes ($_POST['hdd_name']);
   $date_archived = addslashes ($_POST['date_archived']);
   $project_name = addslashes ($_POST['project_name']);
   $archived_by = addslashes ($_POST['archived_by']);
   $other_information = addslashes ($_POST['other_information']);
else
   $hdd_name = $_POST['hdd_name'];
   $date_archived = $_POST['date_archived'];
   $project_name = $_POST['project_name'];
   $archived_by = $_POST['archived_by'];
   $other_information = $_POST['other_information'];
$sql = "INSERT INTO hdd_archive ".
       "(hdd_name,date_archived,project_name,archived_by,other_information) ".
       "VALUES('$hdd_name','$date_archived','$project_name','$archived_by','$other_information', NOW())";
mysql_select_db('team_bnlproductions');
$retval = mysql_query( $sql, $conn );
if(! $retval )
  die('Could not enter data: ' . mysql_error());
echo "Entered data successfully\n";
mysql_close($conn);
else
<form method="post" action="<?php $_PHP_SELF ?>">
<table width="400" border="0" cellspacing="1" cellpadding="2">
<tr>
<td width="100">Hard Drive Name</td>
<td><input name="hdd_name" type="text" id="hdd_name"></td>
</tr>
<tr>
<td width="100">Date Archived</td>
<td><input name="date_archived" type="text" id="date_archived"></td>
</tr>
<tr>
<td width="100">Project Name	</td>
<td><input name="project_name" type="text" id="project_name"></td>
</tr>
<tr>
<td width="100">Archived By</td>
<td><input name="archived_by" type="text" id="archived_by"></td>
</tr>
<tr>
<td width="100">Other Information</td>
<td><input name="other_information" type="text" id="other_information"></td>
</tr>
<tr>
<td width="100"> </td>
<td> </td>
</tr>
<tr>
<td>
<input name="add" type="submit" id="add" value="Submit Entry">
</td>
</tr>
</table>
</form>
<?php
</body>
</html>
You appear to be setting a timestamp in the values that isn't in the list of columns in your insert statement.
Magic quotes feature has been removed from PHP since version 5.4, so I wouldn't rely on it at all (even if it's enabled on your version of PHP, it's still not secure).
Take a look at data sanitation via RegEx; or even better, use a more up-to-date database interface like PDO or MySQLi that support prepared statements. It's far more secure, and since the code is very clearly structured it should be easier to debug.
You're specifying 5 columns to receive data, but supplying 6 columns of actual data.
i.e. you've not given a column name for your NOW() timestamp
