I have a temporary table that I use to populate all of my other tables, naturally the temporary table has everything in it. So to insert to another table I have inserts like this
Which works great when channels is empty. Sometimes however I get an error which says something along the lines of 'Duplicate channelid '12345' exists for primary key'
So it sounds like I'm trying to insert a channelid which already exists in channels.
Essentially I want to insert anything from channeltemp that isn't in channels.
In an attempt to refresh my knowledge on joins I found this diagram.
To me this indicated that I needed the same SQL as above but a right join instead. This however doesn't give me any inserts into the channels table!
Code:
INSERT INTO CHANNELS(CHANNELID,CHANNELNAME)
SELECT
T.CHANNELID, T.CHANNELNAME
FROM
CHANNELTEMP T
LEFT JOIN CHANNELS C ON C.CHANNELNAME=T.CHANNELNAME
WHERE C.CHANNELNAME IS NULL
GROUP BY T.CHANNELNAME
![VQ5XP.png](http://i.stack.imgur.com/VQ5XP.png)
