SQL - Looping a stored procedure
~J~
~J~
20 Oct 2003
London
Currently using MS SQL2000 and have a stored procedure that accepts 3 parameters...
@intYear,
@intPeriod,
@intCostCentre.
I've a table that is full of costcentre nominal codes, and want to run the stored procedure for each cost centre in the table.
For example...
SELECT mySP @intYear=2005, @intPeriod=5, @intCostCentre=SELECT costCentre FROM costCentreTable
Obviously that doesn't work but I'm sure I've read somewhere about using the IN statement to achieve this.
Any ideas?
TIA
Thanks. But that wouldn't actually run the stored procedure as it's not going through each row in the costcentre table.
Even if I could parse the command into a string, I could run it dynamically.
Was hoping to finish at 16:00 today too :)
gah, sorry my brain hurts today
select sp_name(column name) from table should return you whatever the sp returns for each row in the table I think
HT
Create another Stored procedure that references the Sp you have created.
Then in this second stored proc do the following:
NB: SQL will be slightly wrong as haven't got MSSQL here to test
CREATE PROC RunThroughAllCostCentres
AS
DECLARE @intCostCentre INT
DECLARE costCentreCursor CURSOR FOR
SELECT DISTINCT costCentre
FETCH NEXT FROM costCentreCursor INTO @intCostCentre
WHILE @@FETCHSTATUS =0
BEGIN
EXEC SP_EXECUTESQL 'SpNameAlreadyCreated 2005, 5,''' + @intCostCentre + ''''
END
CLOSE costCentreCursor
DEALLOCATE costCentreCursor
GO
Something like above should give you what you want
@oneilldo - PERFECT!!!!! Cheers mate, just had to change @@FETCHSTATUS to include an underscore, but other than that spot on!
Thanks HT adn arty too for your help, much appreciated.
roboffer said:
Yeah, that's a downside, but I'll rework on that over the weekend to get rid, it was the 'logic' I wanted as my trusty old faithful SQL cookbook is 300 miles away :(
Ahh I must start to do something else instead of SQL at work from now on, if I can remember syntax almost exaxctly for cursors whilst typing into OcUK forums then i really need to get out more
