SQL Management studio
18 Oct 2002
Yorkshire
where can I get the information on this from the microsoft page ?
Been looking now for a good 2 hours and the only thing I can find is the express version of it which is ni good for me as it doesn't allow you to import data.
Whats even more annoying is that I had the app for a good month now and uninstalled it was night to try and fix a problem but ths morning I can;t find where it got installed from. can't find it on the SQL 2005 disk and I don't think its on the Visual studio 2005 disk.
any ideas guys ?
It's on the SQL 2005 disk. You wont be able to download it because it's a licensed product (like Enterprise manager was).
Without access to the disks (at work), I cant tell you the exact option you want, but it will be an option on disk 1 setup somewhere.
thanks mate will take a look see whats on it
Update:
Found it, its part of the workstation components, thing is when I was trying it, it was detecting some previously installed components so wasent installing the updated ones on the disk. I had to manualy tell it to upgrade the components :(
on well thats nearly 2 1/2 hours of my life i'd like back microsoft.
thanks again mate for pointing me in the right direction
