SQL Matrix Help
25 Feb 2007
Midlands
Hi,
I currently have a table that looks like this:
[Question 1] [Question 2] [Question 3] [Question 4]
Answer A Answer C Answer A Answer B
Answer B Answer B Answer C Answer A
Answer A Answer A Answer C Answer B
Answer C Answer A Answer C Answer B
Answer C Answer C Answer B Answer B
I need to somehow pivot this so that it looks like this:
Answer A Answer B Answer C
[Question 1] 2 1 2
[Question 2] 2 1 2
[Question 3] 1 1 3
[Question 4] 1 4 0
How could I do this? I imagine my indenting will go crappy when I post this so it's more difficult to read....
Cheers!
Table creation:
Code:
CREATE TABLE [dbo].[Table1]
    [Question1] NCHAR(10) NOT NULL ,
    [Question2] NCHAR(10) NOT NULL,
    [Question3] NCHAR(10) NOT NULL,
    [Question4] NCHAR(10) NOT NULL
Data insert:
Code:
INSERT INTO [dbo].[Table1] ([Question1], [Question2], [Question3], [Question4]) VALUES (N'A         ', N'C         ', N'A         ', N'B         ')
INSERT INTO [dbo].[Table1] ([Question1], [Question2], [Question3], [Question4]) VALUES (N'B         ', N'B         ', N'C         ', N'A         ')
INSERT INTO [dbo].[Table1] ([Question1], [Question2], [Question3], [Question4]) VALUES (N'A', N'A', N'C', N'B')
INSERT INTO [dbo].[Table1] ([Question1], [Question2], [Question3], [Question4]) VALUES (N'C         ', N'A         ', N'C         ', N'B         ')
INSERT INTO [dbo].[Table1] ([Question1], [Question2], [Question3], [Question4]) VALUES (N'C', N'C', N'B', N'B')
Initial Selection:
Code:
SELECT [Question1], [Question2], [Question3], [Question4] FROM dbo.Table1
Question1	Question2	Question3	Question4
A         	C         	A         	B
B         	B         	C         	A
A         	A         	C         	B
C         	A         	C         	B
C         	C         	B         	B
Unpivot Selection:
Code:
SELECT CAST (QuestionID AS NCHAR) AS QuestionID, Answer
FROM (SELECT [Question1], [Question2], [Question3], [Question4] FROM dbo.Table1) AS p
UNPIVOT (Answer FOR QuestionID IN ([Question1], [Question2], [Question3], [Question4])) AS s
QuestionID	Answer
Question1       A
Question2       C
Question3       A
Question4       B
Question1       B
...etc.
Unpivot + Pivot Selection:
Code:
SELECT QuestionID, [A], [B], [C]
FROM
(SELECT CAST (QuestionID AS NCHAR) AS QuestionID, Answer
UNPIVOT (Answer FOR QuestionID IN ([Question1], [Question2], [Question3], [Question4])) AS s) AS pivTemp
PIVOT
	(COUNT(Answer)
	FOR Answer IN ([A], [B], [C])
) As PivTable
QuestionID	A	B	C
Question1 	2	1	2
Question2 	2	1	2
Question3 	1	1	3
Question4 	1	4	0
How's that?
Slight thread revival!
Same sort of thing, although now I have a list of questions and answers (not dissimilar to the UNPIVOT example shown by s-p above) and I need the question text to become the column name or header, and the related answer to show in each column.
There can be an unlimited number of questions and I wouldn't necessarily know the question text.
Can you help?
