SQL: Missing IN or OUT parameter at index:: 1
18 Oct 2002
Can anyone help with this? I've got a "Missing IN or OUT parameter at index:: 1" error and I'm not sure where the solution lies:
Code:
[B]Error starting at line 9 in command:[/B]
Declare @lngNextSCScriptId int
	Declare @lngSitePrefixId int
	Declare @CheckKey smallint
	Declare @lngCount int
	Declare @strObjectName varchar(255)
	Declare @lngNextKey int
	Declare @ErrMsg	varchar(255)
	Declare @InfoMsg varchar(200)
	Declare @RowCount int
	Declare @Error int
	Declare @SCRN  int
	Declare @SupportPerson varchar(50)
	Declare @Description varchar(255)
	Declare @CodeVersion varchar(15)
	Declare @RunMode varchar(15)
-- Extra Variables (specific to call)
	DECLARE @count INT
	BEGIN TRANSACTION
	SET NOCOUNT ON
-- Set Parameters
	-- INITIALISE
	SET @InfoMsg		= 'DB changes Successful'
	-- SCSCRIPTS INFO
	SET @SCRN		= '12345'
	SET @SupportPerson	= 'xxx'
	SET @Description	= 'xxx'
	SET @CodeVersion	= 'xxx'
	-- SETTING ROLLBACK / COMMIT
	SET @RunMode = 'ROLLBACK'
	--SET @RunMode = 'COMMIT'  -- ** Uncomment to run in Commit Mode
	IF @RunMode = 'COMMIT'
		BEGIN
			PRINT '********************'
			PRINT '** IN COMMIT MODE **'
		END
	ELSE
		BEGIN
			PRINT '*****************'
			PRINT '** IN ROLLBACK **'
		END
	PRINT CHAR(10)+ UPPER(@Description) -- ** will display message saved to ScScripts
	PRINT ''
-- Start of Database changes
	PRINT 'Processing ...' + CHAR(10)
	-- ** Each database update / insert / delete to have a display message
	-- ** (or per group of updates/inserts/deletes if many statements for one change)
	PRINT '  ...'
	UPDATE PolicyInterestedParty Set SequenceNo=4 Where PolicyId=1101275 AND PolEffDate=TO_DATE('10-JUL-2014', 'dd-mon-yyyy') AND SequenceNo=10 AND InfoId=21 And CompTypeId=-999;
	UPDATE PolicyInterestedParty Set SequenceNo=4 Where PolicyId=1101275 AND PolEffDate=TO_DATE('10-JUL-2014', 'dd-mon-yyyy') AND SequenceNo=10 AND InfoId=22 And CompTypeId=-999;
	UPDATE PolicyInterestedParty Set SequenceNo=4 Where PolicyId=1101275 AND PolEffDate=TO_DATE('10-JUL-2014', 'dd-mon-yyyy') AND SequenceNo=10 AND InfoId=23 And CompTypeId=-999;
	UPDATE PolicyInterestedParty Set SequenceNo=4 Where PolicyId=1101275 AND PolEffDate=TO_DATE('10-JUL-2014', 'dd-mon-yyyy') AND SequenceNo=10 AND InfoId=27 And CompTypeId=-999;
	UPDATE PolicyInterestedParty Set SequenceNo=4 Where PolicyId=1101275 AND PolEffDate=TO_DATE('10-JUL-2014', 'dd-mon-yyyy') AND SequenceNo=10 AND InfoId=161 And CompTypeId=-999;
	SELECT @Error = @@ERROR
		IF @Error <> 0
			BEGIN
				SET @ErrMsg = 'Error: Delete Failed! Error Code: '+ cast(@Error as varchar(10))
				goto error_terminate
			END
	UPDATE PolicyInterestedParty Set SequenceNo=5 Where PolicyId=1101275 AND PolEffDate=TO_DATE('10-JUL-2014', 'dd-mon-yyyy') AND SequenceNo=10 AND InfoId=21 And CompTypeId=120;
	UPDATE PolicyInterestedParty Set SequenceNo=5 Where PolicyId=1101275 AND PolEffDate=TO_DATE('10-JUL-2014', 'dd-mon-yyyy') AND SequenceNo=10 AND InfoId=22 And CompTypeId=120;
	UPDATE PolicyInterestedParty Set SequenceNo=5 Where PolicyId=1101275 AND PolEffDate=TO_DATE('10-JUL-2014', 'dd-mon-yyyy') AND SequenceNo=10 AND InfoId=23 And CompTypeId=120;
	UPDATE PolicyInterestedParty Set SequenceNo=5 Where PolicyId=1101275 AND PolEffDate=TO_DATE('10-JUL-2014', 'dd-mon-yyyy') AND SequenceNo=10 AND InfoId=27 And CompTypeId=120;
	UPDATE PolicyInterestedParty Set SequenceNo=5 Where PolicyId=1101275 AND PolEffDate=TO_DATE('10-JUL-2014', 'dd-mon-yyyy') AND SequenceNo=10 AND InfoId=161 And CompTypeId=120;
		IF @Error <> 0
			BEGIN
			END
-- End of Database changes
	PRINT CHAR(10) + 'Complete'
-- Log Database Change
	-- GET SITE PREFIX ID
	Set @lngSitePrefixId = (Select SettingText From SystemSetting Where SystemId In (Select SystemId From SystemList Where SystemName = 'MAINFRAMEWORK') and SettingDescription = 'Site Id Prefix')
	IF @lngSitePrefixId = 0 or @lngSitePrefixId is null
	   Begin
		  Set @ErrMsg = 'Error: Cannot find a valid site id prefix. Processing terminated.'
		  GoTo error_terminate
	   End
	-- GET THE NEXT SCSCRIPTID FROM LAST PRIMARY KEY
	Set @CheckKey = 0
	While @CheckKey = 0
	   Begin
		  Set @strObjectName = 'SCScript'
		  Set @lngNextKey = (Select NextKey from LastPrimaryKey where ObjectName = @strObjectName)
		  -- Update last primary key for the SCScript record
		  if @lngNextKey = 0 or @lngNextKey is null
			 Begin
				Set @lngNextKey = 2
				Insert Into LastPrimaryKey (ObjectName, NextKey) Values (@strObjectName, @lngNextKey)
			 End
		  else
			 Begin
				Set @lngNextKey = @lngNextKey + 1
				Update LastPrimaryKey Set NextKey = @lngNextKey Where ObjectName = @strObjectName
			 End
		  -- check to ensure that the ScriptId is valid (i.e. not already used)
		  Set @lngNextSCScriptId = @lngNextKey - 1
		  set @lngNextSCScriptId = cast((cast(@lngSitePrefixId as varchar) + cast(@lngNextSCScriptId as varchar)) as int)
		  --print @strObjectName + cast(@lngNextKey as varchar)
		  Set @lngCount = (Select Count(*) From SCScripts Where ScriptId = @lngNextSCScriptId)
		  if @lngCount = 0 or @lngCount is null
			 Set @CheckKey = 1 -- we have a valid key
		  Else
			 Begin
				Set @CheckKey = 0 --get the next one
				Set @lngNextSCScriptId = 0
			 End
	   End
	-- ERROR IF SCRIPT ID CANNOT BE FOUND
	IF @lngNextSCScriptId = 0 or @lngNextSCScriptId is null
	   Begin
		  Set @ErrMsg = 'Error: Cannot find the next valid Script Id. Processing terminated.'
	   End
	-- WRITE TO SCRIPT LOG TABLE
	INSERT INTO SCScripts (ScriptId, SCRN, SupportAnalystName, RunDate, Description, VersionNo)
	VALUES (@lngNextSCScriptId, @SCRN, @SupportPerson, GetDate(), @Description, @CodeVersion)
	--	select top 2 * from SCScripts order by 1 desc -- ** uncomment to see log entry when testing
	-- ALL IS WELL - END NORMALLY
	GOTO normal_termination
-- Termination points
	-- WHEN ERROR IS ENCOUNTED
	error_terminate:
	PRINT @ErrMsg
	PRINT ''
	PRINT '------------------------'
	PRINT 'Updates Failed. Rolling Back'
	ROLLBACK TRANSACTION
	GOTO end_of_script
	-- WHEN SCRIPT RUNS SUCCESSFULLY
	normal_termination:
	PRINT ''
	PRINT @InfoMsg
		BEGIN
			COMMIT TRANSACTION; PRINT '** COMMITTED **'
		END
	ELSE
		BEGIN
			ROLLBACK TRANSACTION; PRINT '(Rolled Back)'
		END
-- Final Exit Point
end_of_script:
Error report:
[B]Missing IN or OUT parameter at index:: 1[/B]
Many thanks,
B@
