SQL: Passing a parameter for an IN clause.
~J~
~J~
20 Oct 2003
London
Anyone know an answer to this?
Got a SELECT statement which uses an IN clause to determine what rows to retrieve.
EG. SELECT name FROM emps WHERE uid IN (10,12,14)
What I'm trying to do however is create a parameter, pass in a comma seperated list and then use this as the IN clause.
EG.
DECLARE @emps NVARCHAR(30)
SET @emps ='10,12,33'
SELECT name FROM emps WHERE uid IN (@emps)
Now this is failing, and I know why it's failing because the parameter is of nvarchar type yet the uid is of int.
I can't change the @emps parameter to int, because I then can't have a comma-seperated list!
Any thoughts on how I may be able to do this?
I had this problem a while back. The only workaround I found was to actually build the SQL command text in the SP itself...
Code:
DECLARE @In_List nvarchar(256)
DECLARE @SQL nvarchar(4000)
SET @In_List = '12,13,15'
SET @SQL = 'SELECT [Field] FROM [Table] WHERE [ID_Field] IN
(' + @In_List + ')'
CALL sp_executesql @SQL
HTH!
