- 25 Mar 2004
- Fareham
Hello good citizens of OCUK,
I've got a SQL table that contains information about users in different accounts/companies. Each night a script runs against AD, finds all of the users, and then looks at the table data in SQL and does the following:
So I'd like to be able to step back in time to see how many users a particular company had on any given date. I think I can do that with the data I have been building/collecting.
The Users table in SQL has the following columns for this purpose:
I've come up with this script, can anyone think of a better/more efficient way of pulling this query data?
I think it works OK but I am not a SQL god or anything, and SQL can do a lot I am not aware about
Essentially my thinking is that for any given date I am going back through, as long as the createTimeStamp (taken from AD) is the current date or less, and as long as the DeletedDate field is either NULL (still exists) or greater than the current date (deleted on a later date) then I can do a count of those users in that criteria to get the number of users who were still present on that date.
- If the user is a new user it inserts a new row for it.
- If the user was in SQL the night before, but is now gone, it tags the DeletedDate column with the current date.
- If the user still exists it just updates the row with any new/current info.
Code:
[CompanyName] [nvarchar](255) NULL
[createTimeStamp] [datetime] NULL
[DeletedDate] [date] NULL
Code:
-- Temp Table
CREATE TABLE #UserCounts
[Date] date,
[UserCount] int
-- How many days to go back
DECLARE @DayCount int;
SET @DayCount = -30;
-- Company Name
DECLARE @CompanyName varchar(255);
SET @CompanyName = 'Test Company'
-- Loop through X days
WHILE (@DayCount < 0)
BEGIN
-- Increment Date var
SET @DayCount = @DayCount + 1;
-- Get Current Date positionally
DECLARE @CurrentDate date;
SET @CurrentDate = CAST(DATEADD(d, @DayCount, GETDATE()) AS date);
-- Insert Current Date values into Temp Table
INSERT INTO #UserCounts
SELECT
@CurrentDate AS [Date],
COUNT (createTimeStamp) AS [UserCount]
FROM Users
WHERE CompanyName = @CompanyName
AND CAST(createTimeStamp AS date) <= @CurrentDate
AND (DeletedDate IS NULL OR DeletedDate > @CurrentDate)
END;
