SQL Query Help
13 Nov 2003
Manchester
Hi All
I am experimenting with Sphider as a search engine for a site I am working on. However I cant stop the spider from indexing some pages that I dont want in there. So to get rid of them I will need to run an sql query.
I need the query to do the following.
DELETE all from Links where '**' does not contain product_details.php
Have been on the goog for ages and not found anything. Any ideas/
Thanks
Aaron
Code:
DELETE FROM `table` WHERE `column` = 'value';
Or, if you are deleting based upon a sub-string:
Code:
DELETE FROM `table` WHERE `column` LIKE '%value%';
The problem with robots.txt is that it will stop the spider from spidering the pages, I want it to spider but not to index.
Basically I only want it to index pages that have product_details.asp in the URL
Thanks
Aaron
TrUz said:
Is that not the whole point of spidering web pages - to index them?
TrUz
No in this case. We are only using the spider to make an index of all of the product pages on our site. To make the on site search better
Its not for google etc
Does it support the robots <meta> tag? You can indicate how you want the pages to be spidered:
Code:
<meta name="robots" content="noindex,follow" />
Doesn't index, but does follow links.
