SQL query help
marc2003 said:
well i've changed it but i'm not too sure if it makes any difference. for example if i dump the whole database on one page, it takes about 8 seconds using both timing methods. :p
Figured it was wrong on mine when i got timings like -3.043 seconds :D
well i never had negative results. maybe it was a platform/php version thing. i'm running php5 at home on windows. :)
Jaffa_Cake said:
As you can see my signature updates, does this using the GD library in PHP. It currently stores a ton of log information in SQL which is nearly 24,000 entries all containing IP, browser, time and referrer.
Im making a stats file, i've got many things such as how many times your IP viewed the signature, total number of unique viewers etc. ( got some very interesting numbers )
I am trying to find the most popular referrer. To do this i currently use a SELECT DISTINCT then loop through every result which takes absolutly ages seeing as its over 1800 queries.
I'm sure this is possible but i can't seem to find it. Need to find which link is most common in the logs table.
Help please :)
Using Oracle SQL
Select referrer, count (referrer) group by referrer from table;
Kronologic said:
Using Oracle SQL
Im using MySQL, I am using a very similar syntax and I have it working but it has yet to be implemented :) Pending lots of cool new features too. :D :D
Just a few tips, they won't make a great deal of difference to your script, but it's best to get into good habbits early on so that you automatically write optimized code.
If your string doesn't contain a variable that needs to be evaluated or a special character, then use single quotes instead of double quotes. This saves execution time because PHP knows that the string is just a string and doesn't require any special attention.
When all you're doing is essentially counting stuff, let the database do the work for you. Try and return as few rows as possible, preferably with everything already totaled:
Code:
SELECT agent, COUNT(agent) AS frequency
FROM logs
GROUP BY agent
ORDER BY COUNT(agent) DESC
That should give you a list of agents, with a count of their frequency, ordered by frequency.
If you're filtering by time, then provide your time range in the query rather than returning all rows and then discarding unneeded data with PHP:
Code:
FROM logs
WHERE time >= '$someDateInPast'
GROUP BY agent
When you're returning results from mysql, use mysql_fetch_assoc or mysql_fetch_row rather than mysql_fetch_array unless you explicitly need both indexed and associative arrays (unlikely), otherwise you're returning duplicate rows uneccessarily.
When you're comparing the result of an expression multiple times, first assign the result of the expression to a variable and compare against that so you're not performing exactly the same process over and over again.
i.e.
Code:
..snip..
$agent = strtolower($row2['agent']);
if(strstr($agent , "linux")) {
	if(strstr($agent , "debian")) {
..snip..
LazyManc said:
Code:
FROM logs
GROUP BY agent
just been playing with that and it works well but i want to only to run it on unique ips. i couldn't find anything much to help until i stumbled upon creating a "view". it works but is that the right way to go about it? this is how my useragent loop looks now....
Code:
mysql_query("CREATE VIEW v AS SELECT agent, time FROM logs GROUP BY ip");
$result2 = mysql_query("SELECT agent, COUNT(agent) AS frequency FROM v GROUP BY agent ORDER BY COUNT(agent) DESC");
while($row2 = mysql_fetch_assoc($result2)) {
	$frequency = $row2['frequency'];
	if(strstr($agent, "firefox")) {
		$browser['firefox'] += $frequency;
	if(strstr($agent, "opera")) {
		$browser['opera'] += $frequency;
edit: doing this and changing how i count the hits has shaved a few tenths of a second off the time even though i now have 8 queries now instead of 3. it's now always under 0.2s. :cool:
LazyManc said:
Code:
FROM logs
GROUP BY agent
Showing rows 0 - 29 (967 total, Query took 1.5675 sec)
SQL query:
Code:
SELECT browser, COUNT( browser ) AS frequency
FROM jaffa_cake_logs
GROUP BY browser
ORDER BY COUNT( browser ) DESC
LIMIT 0 , 30
I'm not liking the look of that 1.5 seconds. I'l have a play with it.
Maybe its my server being sucky :( Sends server CPU to 100% while it does the query.
Edit: Or maybe its because its trawling through 54,927 entries :D
i've finished mine now. i'm using the builtin mysql date/time functions instead of php and added a little colour. :)
got rid of the referring pages as it's useless. :D
got rid of the referring pages as it's useless. :D[/QUOTE]
I like very much. Will be trying to beat your stats page today. Have been working on the physical signature code yesterday.
All text on the image is pulled from SQL, added special commands such as {UVIEWS} and {TVIEWS} {CREATED} etc. Main message is pulled from SQL which looks like this:
[CODE]
You are viewer: {TVIEWS}
Unique viewers: {UVIEWS}
[/CODE]
and in the bottom left is lifted from SQL which uses the {CREATED} command :).
Will be working on stats soon :) Been looking at this [url]http://www.aditus.nu/jpgraph/[/url]
[SIZE=1][COLOR=Red]Yes, I do have too much free time[/COLOR][/SIZE]
LazyManc said:
Have you guys seen google analytics?
i think we both realise there is much better stuff out there, i just did it to learn a little php/mysql. :)
bbclone is a nice stat counter too. i've used that in the past. (it's where i pinched the browser/os icons for my page. :p)
