SQL query missing expression?
Thug
4 Jan 2013
SELECT CustomerNumber.invoices, COUNT(InvoiceNumber.invoices) AS NumberofInvoices,
FROM Invoices INNER JOIN customers
ON customernumber.invoices = customernumber.customers
GROUP BY CustomerNumber
HAVING CustomerNumber=1;
I'm trying to get the number of invoices sent to one person but its spitting up an error on line 2.
Anyone got a quick tip? Thanks.
Your table names need to be on the left-hand-side of the dot - so if your table name is Invoices you should be selecting 'Invoices.CustomerNumber', not 'CustomerNumber.Invoices'
Also another query problem I have is:
SELECT purchaseordernumber, SUM(quantityordered*costpriceperunit)
FROM purchaseorderline
GROUP BY purchaseordernumber
HAVING purchaseordernumber=10005;
I'm trying to find the total cost of purchase order (as shown below)
Any ideas? Really appreciate it. :)
Shouldn't have a comma before FROM
Thanks, I got rid of it, and swapped a line down, and seem to have made some progress.
ON invoices.customernumber =customers.customernumber
It is now saying line 5 is ambiguously defined (having customernumber=1).
Is there a better way to say it?
You shouldn't need to use HAVING in that particular query - try it with 'WHERE CustomerNumber=1' instead.
Your other issue to do with multiplying and sum looks ok to me.. try sticking an alias on the SUM() column, so it's:
SELECT purchaseordernumber, SUM(quantityordered*costpriceperunit) AS Total
changing it to where, eg
WHERE CustomerNumber=1;
gives the error SQL command not properly ended. :(
The other issue when I do that just gives the result:
Using my data so it makes sense.
Just change the field names, table names - basically your where needs to be before the group by.
SELECT
elec.ADDRESS,
COUNT(elec.MPAN + gas.mprn) AS STUFF
FROM dbo.elec_stuff elec INNER JOIN dbo.gas_stuff gas
ON gas.ADDRESS= elec.ADDRESS
WHERE elec.DATA_ITEM = 'STUFF'
GROUP BY elec.ADDRESS
Sorry, the WHERE clause should be before the GROUP BY...
GROUP BY CustomerNumber;
The answer to your other query is correct:
20*4 = 80
5*4 = 20
80+20 = 100
20*4 = 80
5*4 = 20
80+20 = 100
I just noticed the other one was correct, my bad! :o
It now says it is ambigously defined. :(
Try this,
SELECT
Inv.CustomerNumber
, COUNT(inv.InvoiceNumber) AS NumberofInvoices
FROM
Invoices Inv
JOIN
customers cus
ON
inv.customernumber = cus.customernumber
WHERE
cus.CustomerNumber=1
GROUP BY
cus.CustomerNumber
You need to specify the table & column names everywhere if they are shared.
Edit - ahh beaten like a red headed stepchild.
