SQL Query - Selecting all tables
Hitman
25 Feb 2004
Hey,
Trying to convert ~70 tables to the character set latin1 and wondered if there was a quick way of doing this. SQL query I've got is:
ALTER TABLE tablename CONVERT TO CHARACTER SET latin1;
Sure, it works, but by that I would have to do each table 1-by-1.
Is there a quick "select all" I can put in replace for the tablename? I guessed * would work but it doesn't :)
Cheers.
Look at the procedure sp_msforeachtable
Probably something like...
exec sp_MSForeachtable 'ALTER TABLE ? CONVERT TO CHARACTER SET latin1','?'
..off the top of my head. The ? marks are a deliberate wildcard so don't change 'em.
There is a procedure sp_MSForeachdb which is my favourite. Sad I know.
If you wanna do it yourself, cursors are your friend.
Be careful with alter database, not sure if that just sets the collation of all future tables.
To be honest I didn't realise alter table actually worked either but rarely deviate from Latin1 general anyway.
What am I talking about, not been a DBA for 12 months, should stop pretending!!
