SQL Question
18 Oct 2002
Yorkshire
I've got 3 tables in the query.
Client
ClientSchool
SchoolDetails
Client holds hte general Client details which includes a ClientID
ClientSchool has the foregion Key ClientID and SchoolCode (both foregion keys)
SchoolDetails has the SchoolCode as the key and a schoolName
I'm trying to make a query which looks like so
SELECT
Client.clientName, Client.ClientAddress, ClientNumber, SchoolDetails.schoolName AS School
FROM
Client
LEFT JOIN ClientSchool ON Client.ClientID = ClientSchool.ClientID
LEFT JOIN SchoolDetails ON ClientSchool.SchoolCode = SchoolDetails.schoolName
WHERE (Client.ClientID = '1000123')
This should display ALL the client details from the Client table as well as any SchoolName if it finds a
matching reccord but it doesn't. Any ideas ?
The join path you have will only show a SchoolName if there's a ClientSchool record for the ClientID you have in the WHERE clause.
Have you eyeballed the data to make sure the correct records exist?
yep 100% sure I can do the same query just by extending the where clause
i.e.
FROM Client, SchoolDetails, ClientSchool
WHERE SchoolDetails.SchoolCode = ClientSchool.SchoolCode
AND ClientSchool.ClientID = Client.ClientID
AND Client.ClientID = '1000123'
but i'm wanting to do it with the Joins if possible just the only examples I can find for joins just include 2 tables and not 3.
no worries sorted it. Finally worked out you can nest the joins so did a nested inner join on the two school tables then a left join on the client and the results of the nested join.
