SQL Selecting tables from DB
Not like that but there will probably be a way to do it.
It is different on different databases though, what are you using.
e.g. in Oracle it would be SELECT * FROM all_tables
How do you mean?
Im using SQLYog (A GUI programme that lets you manage the database) the SQL Database itself is located on the SQL server of my web-hosting company.
The syntax can vary between database systems - Oracle being one type of database system, MySQL being another and MSSQL being a third. You haven't specified what database system you are using.
Are you trying to extract data from multiple tables, or just get a list of all the tables in a database? For the latter, you can run the query
Code:
SHOW TABLES;
in MySQL to return that information.
How do i find out what type of database im running on? as i said its running on the web-host i am using and im using a 3rd party package (GUI) that lets me manage the database, then i use PHP as a web-front end to run the SQL query's
Code:
$username="";
$password="";
$database="";
mysql_connect(localhost,$username,$password);
@mysql_select_db($database) or die( "Unable to select database");
$query="SHOW TABLES";
$result=mysql_query($query);
$num=mysql_numrows($result);
mysql_close();
echo  "<b><center>Database Output</center></b><br><br>";
$i=0;
while ($i < $num) {
$catagory=mysql_result($result,$i,"catagory");
$title=mysql_result($result,$i,"title");
$price=mysql_result($result,$i,"price");
$i++;
how would i change
to hold the output for the table information? because it dont contain any fields? its just the table names?
read the php manual, im fairly sure there is a function to list the tables. Thats a mysql database anyway, the references to 'mysql' in the php code give it away :p
You use MySQL :)
Just incase you forgot from last night, SHOW TABLES outputs a result set with one column, and each row contains a table name.
I think sysobjects is an SQL Server system view and shows a lot more than the tables in the current database?
SELECT name
FROM sysobjects
WHERE type = 'U';
will give you the user tables on SQL Server.
HT
Ok, iv managed to pull the table names from the database and iv worked out how to change them to links with abit of help from beansprout.
www.caldicot-pc-helpdesk.co.uk/fcv/database/index3.php
by using the following code
Code:
while($row = mysql_fetch_row($result))
echo '<a href="index8.htm">'.$row[0].'</a>';
echo "<br />";
I want to be able to click this link which is located in 1 div, and the table contents (when clicked) will appear in another div.
What will i have to do to get this? i cant remember the code for targeting a link to another part of the page.
