SQL Server 2005 MSDN installation issues
Man of Honour
Man of Honour
3 May 2004
SILENCE!
This has officially become the most trying installation I have ever attempted and it is riddled with errors and bugs. I need help and Google isn't being my friend at all. Literally poured 3 working days into this now and I'm close to giving up but I really really need to use 2005, not 2000. Basically it gets most of the way through and I receive the following error message:
There was an unexpected failure during the setup wizard. You may review the setup logs and/or click the help button for more information.
The error report takes me to this page but I have a slightly different error in my log file which is: Error: Failed to add file :"C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\
Anyone got any ideas? Full log file is below, note I've replaced my local server name with SERVERNAME for security reasons:
Code:
Microsoft SQL Server 2005 Setup beginning at Tue Jul 15 12:15:49 2008
Process ID      : 3780
C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\setup.exe Version: 2005.90.1399.0
Running: LoadResourcesAction at: 2008/6/15 12:15:49
Complete: LoadResourcesAction at: 2008/6/15 12:15:49, returned true
Running: ParseBootstrapOptionsAction at: 2008/6/15 12:15:49
Loaded DLL:C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\xmlrw.dll Version:2.0.3604.0
Complete: ParseBootstrapOptionsAction at: 2008/6/15 12:15:49, returned true
Running: ValidateWinNTAction at: 2008/6/15 12:15:49
Complete: ValidateWinNTAction at: 2008/6/15 12:15:49, returned true
Running: ValidateMinOSAction at: 2008/6/15 12:15:49
Complete: ValidateMinOSAction at: 2008/6/15 12:15:49, returned true
Running: PerformSCCAction at: 2008/6/15 12:15:49
Complete: PerformSCCAction at: 2008/6/15 12:15:49, returned true
Running: ActivateLoggingAction at: 2008/6/15 12:15:49
Complete: ActivateLoggingAction at: 2008/6/15 12:15:49, returned true
Running: DetectPatchedBootstrapAction at: 2008/6/15 12:15:49
Complete: DetectPatchedBootstrapAction at: 2008/6/15 12:15:49, returned true
Action "LaunchPatchedBootstrapAction" will be skipped due to the following restrictions:
Condition "EventCondition: __STP_LaunchPatchedBootstrap__3780" returned false.
Action "BeginBootstrapLogicStage" will be skipped due to the following restrictions:
Condition "Setup is running locally." returned true.
Running: PerformDotNetCheck2 at: 2008/6/15 12:15:49
Complete: PerformDotNetCheck2 at: 2008/6/15 12:15:49, returned true
Running: InvokeSqlSetupDllAction at: 2008/6/15 12:15:49
Loaded DLL:C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\sqlspars.dll Version:2005.90.1399.0
<Func Name='DwLaunchMsiExec'>
Examining 'sqlspars' globals to initialize 'SetupStateScope'
Opening 'MachineConfigScope' for [SERVERNAME]
Trying to find Product Code from command line or passed transform
If possible, determine install id and type
Trying to find Instance Name from command line.
No Instance Name provided on the command line
If possible, determine action
Machine = SERVERNAME, Article = WMIServiceWin32OSWorking, Result = 0 (0x0)
Machine = SERVERNAME, Article = WMIServiceWin32CompSystemWorking, Result = 0 (0x0)
Machine = SERVERNAME, Article = WMIServiceWin32ProcessorWorking, Result = 0 (0x0)
Machine = SERVERNAME, Article = WMIServiceReadRegWorking, Result = 0 (0x0)
Machine = SERVERNAME, Article = WMIServiceWin32DirectoryWorking, Result = 0 (0x0)
Machine = SERVERNAME, Article = WMIServiceCIMDataWorking, Result = 0 (0x0)
Machine = SERVERNAME, Article = XMLDomDocument, Result = 0 (0x0)
Machine = SERVERNAME, Article = Processor, Result = 0 (0x0)
Machine = SERVERNAME, Article = PhysicalMemory, Result = 0 (0x0)
Machine = SERVERNAME, Article = DiskFreeSpace, Result = 0 (0x0)
Machine = SERVERNAME, Article = OSVersion, Result = 0 (0x0)
Machine = SERVERNAME, Article = OSServicePack, Result = 0 (0x0)
Machine = SERVERNAME, Article = OSType, Result = 0 (0x0)
Machine = SERVERNAME, Article = iisDep, Result = 0 (0x0)
Machine = SERVERNAME, Article = AdminShare, Result = 0 (0x0)
Machine = SERVERNAME, Article = PendingReboot, Result = 0 (0x0)
Machine = SERVERNAME, Article = PerfMon, Result = 0 (0x0)
Machine = SERVERNAME, Article = IEVersion, Result = 0 (0x0)
Machine = SERVERNAME, Article = DriveWriteAccess, Result = 0 (0x0)
Machine = SERVERNAME, Article = COMPlus, Result = 0 (0x0)
Machine = SERVERNAME, Article = ASPNETVersionRegistration, Result = 0 (0x0)
Machine = SERVERNAME, Article = MDAC25Version, Result = 0 (0x0)
Setup Consistency Check Report for Machine: SERVERNAME
Article: WMI Service Requirement, Result: CheckPassed
Article: MSXML Requirement, Result: CheckPassed
Article: Operating System Minimum Level Requirement, Result: CheckPassed
Article: Operating System Service Pack Level Requirement, Result: CheckPassed
Article: SQL Compatibility With Operating System, Result: CheckPassed
Article: Minimum Hardware Requirement, Result: CheckPassed
Article: IIS Feature Requirement, Result: CheckPassed
Article: Pending Reboot Requirement, Result: CheckPassed
Article: Performance Monitor Counter Requirement, Result: CheckPassed
Article: Default Installation Path Permission Requirement, Result: CheckPassed
Article: Internet Explorer Requirement, Result: CheckPassed
Article: Check COM+ Catalogue, Result: CheckPassed
Article: ASP.Net Registration Requirement, Result: CheckPassed
Article: Minimum MDAC Version Requirement, Result: CheckPassed
<Func Name='PerformDetections'>
0
<EndFunc Name='PerformDetections' Return='0' GetLastError='0'>
<Func Name='DisplaySCCWizard'>
CSetupBootstrapWizard returned 1
<EndFunc Name='DisplaySCCWizard' Return='0' GetLastError='183'>
Failed to find help file for LCID :2057
Loaded DLL:C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\sqlsval.dll Version:2005.90.1399.0
<EndFunc Name='DwLaunchMsiExec' Return='0' GetLastError='0'>
Complete: InvokeSqlSetupDllAction at: 2008/6/15 12:20:0, returned true
Running: SetPackageInstallStateAction at: 2008/6/15 12:20:0
1: SQL_Engine = 2
1: SQL_Data_Files = 2
1: SQL_Replication = 2
1: SQL_FullText = 2
1: SQL_SharedTools = 2
1: SQL_BC_DEP = 2
2: Analysis_Server = 3
2: AnalysisDataFiles = 3
2: AnalysisSharedTools = 3
3: RS_Server = 2
3: RS_Web_Interface = 2
3: RS_SharedTools = 2
4: Notification_Services = 2
4: NS_Engine = 2
4: NS_Client = 2
5: SQL_DTS = 2
6: Client_Components = 2
6: TOOLS_BC_DEP = 2
6: Connectivity = 2
6: Tools_Legacy = 2
6: SQL_Tools90 = 2
6: SQL_WarehouseDevWorkbench = 2
6: SDK = 2
6: SQLXML = 2
6: SQL_BooksOnline = 2
6: SQL_Documentation = 2
6: SQL_Samples = 2
6: SQL_DatabaseSamples = 2
6: SQL_AdventureWorksSamples = 2
6: SQL_AdventureWorksDWSamples = 2
6: SQL_AdventureWorksASSamples = 2
1: SQL_Engine = 2
1: SQL_FullText = 2
1: SQL_BC_DEP = 2
3: RS_Server = 3
3: RS_Web_Interface = 3
3: RS_SharedTools = 3
4: NS_Engine = 2
4: NS_Client = 2
5: SQL_DTS = 2
6: TOOLS_BC_DEP = 2
6: Connectivity = 2
6: Tools_Legacy = 2
6: SQL_Tools90 = 2
6: SDK = 2
6: SQLXML = 2
6: SQL_Samples = 2
1: SQL_Engine = 3
1: SQL_Data_Files = 3
1: SQL_Replication = 3
1: SQL_FullText = 3
1: SQL_SharedTools = 3
1: SQL_BC_DEP = 3
4: NS_Engine = 2
4: NS_Client = 2
5: SQL_DTS = 2
6: TOOLS_BC_DEP = 2
6: Connectivity = 2
6: Tools_Legacy = 2
6: SQL_Tools90 = 2
6: SDK = 2
6: SQLXML = 2
6: SQL_Samples = 2
4: NS_Engine = 2
4: NS_Client = 2
5: SQL_DTS = 3
6: TOOLS_BC_DEP = 2
6: Connectivity = 2
6: Tools_Legacy = 2
6: SQL_Tools90 = 2
6: SDK = 2
6: SQLXML = 2
6: SQL_Samples = 2
Complete: SetPackageInstallStateAction at: 2008/6/15 12:20:6, returned true
Running: DeterminePackageTransformsAction at: 2008/6/15 12:20:6
Complete: DeterminePackageTransformsAction at: 2008/6/15 12:20:8, returned true
Running: ValidateSetupPropertiesAction at: 2008/6/15 12:20:9
Complete: ValidateSetupPropertiesAction at: 2008/6/15 12:20:9, returned true
Running: OpenPipeAction at: 2008/6/15 12:20:9
Complete: OpenPipeAction at: 2008/6/15 12:20:9, returned false
Error: Action "OpenPipeAction" failed during execution.
Running: CreatePipeAction at: 2008/6/15 12:20:9
Complete: CreatePipeAction at: 2008/6/15 12:20:9, returned false
Error: Action "CreatePipeAction" failed during execution.
Action "RunRemoteSetupAction" will be skipped due to the following restrictions:
Condition "Action: CreatePipeAction has finished and passed." returned false.
Running: PopulateMutatorDbAction at: 2008/6/15 12:20:9
Complete: PopulateMutatorDbAction at: 2008/6/15 12:20:9, returned true
Running: GenerateRequestsAction at: 2008/6/15 12:20:9
	SQL_Engine = -1
	SQL_Data_Files = -1
	SQL_Replication = -1
	SQL_FullText = -1
	SQL_SharedTools = -1
	SQL_BC_DEP = -1
	Analysis_Server = -1
	AnalysisDataFiles = -1
	AnalysisSharedTools = -1
	RS_Server = -1
	RS_Web_Interface = -1
	RS_SharedTools = -1
	Notification_Services = 3
	NS_Engine = 3
	NS_Client = 3
	SQL_DTS = -1
	Client_Components = 3
	Connectivity = 3
	SQL_Tools90 = 3
	SQL_WarehouseDevWorkbench = 3
	SDK = 3
	SQLXML = 3
	Tools_Legacy = 3
	TOOLS_BC_DEP = 3
	SQL_Documentation = 3
	SQL_BooksOnline = 3
	SQL_DatabaseSamples = -1
	SQL_AdventureWorksSamples = -1
	SQL_AdventureWorksDWSamples = -1
	SQL_AdventureWorksASSamples = -1
	SQL_Samples = -1
Complete: GenerateRequestsAction at: 2008/6/15 12:20:11, returned true
Running: CreateProgressWindowAction at: 2008/6/15 12:20:11
Complete: CreateProgressWindowAction at: 2008/6/15 12:20:11, returned true
Running: ScheduleActionAction at: 2008/6/15 12:20:11
Complete: ScheduleActionAction at: 2008/6/15 12:20:12, returned true
Skipped: InstallASAction.11
Skipped: Action "InstallASAction.11" was not run.  Information reported during analysis:
No install request found for package: "sqlsupport", referred by package: "as", install will be skipped as a result.
Skipped: InstallASAction.18
Skipped: Action "InstallASAction.18" was not run.  Information reported during analysis:
No install request found for package: "owc11", referred by package: "as", install will be skipped as a result.
Skipped: InstallASAction.22
Skipped: Action "InstallASAction.22" was not run.  Information reported during analysis:
No install request found for package: "bcRedist", referred by package: "as", install will be skipped as a result.
Skipped: InstallASAction.9
Skipped: Action "InstallASAction.9" was not run.  Information reported during analysis:
No install request found for package: "msxml6", referred by package: "as", install will be skipped as a result.
Skipped: InstallDTSAction
Skipped: Action "InstallDTSAction" was not run.  Information reported during analysis:
No install request found for package: "dts", install will be skipped as a result.
Skipped: InstallDTSAction.11
Skipped: Action "InstallDTSAction.11" was not run.  Information reported during analysis:
No install request found for package: "sqlsupport", referred by package: "dts", install will be skipped as a result.
Skipped: InstallDTSAction.12
Skipped: Action "InstallDTSAction.12" was not run.  Information reported during analysis:
No install request found for package: "sqlncli", referred by package: "dts", install will be skipped as a result.
Skipped: InstallDTSAction.18
Skipped: Action "InstallDTSAction.18" was not run.  Information reported during analysis:
No install request found for package: "owc11", referred by package: "dts", install will be skipped as a result.
Skipped: InstallDTSAction.22
Skipped: Action "InstallDTSAction.22" was not run.  Information reported during analysis:
No install request found for package: "bcRedist", referred by package: "dts", install will be skipped as a result.
Skipped: InstallDTSAction.9
Skipped: Action "InstallDTSAction.9" was not run.  Information reported during analysis:
No install request found for package: "msxml6", referred by package: "dts", install will be skipped as a result.
Running: InstallNSAction.11 at: 2008/6/15 12:20:12
Installing: sqlsupport on target: SERVERNAME
Complete: InstallNSAction.11 at: 2008/6/15 12:20:15, returned true
Running: InstallNSAction.12 at: 2008/6/15 12:20:15
Installing: sqlncli on target: SERVERNAME
Complete: InstallNSAction.12 at: 2008/6/15 12:20:20, returned true
Running: InstallNSAction.18 at: 2008/6/15 12:20:20
Installing: owc11 on target: SERVERNAME
Complete: InstallNSAction.18 at: 2008/6/15 12:20:22, returned true
Running: InstallNSAction.22 at: 2008/6/15 12:20:22
Installing: bcRedist on target: SERVERNAME
Complete: InstallNSAction.22 at: 2008/6/15 12:20:45, returned true
Running: InstallNSAction.9 at: 2008/6/15 12:20:45
Installing: msxml6 on target: SERVERNAME
Complete: InstallNSAction.9 at: 2008/6/15 12:20:49, returned true
Skipped: InstallRSAction.11
Skipped: Action "InstallRSAction.11" was not run.  Information reported during analysis:
No install request found for package: "sqlsupport", referred by package: "rs", install will be skipped as a result.
Skipped: InstallRSAction.18
Skipped: Action "InstallRSAction.18" was not run.  Information reported during analysis:
No install request found for package: "owc11", referred by package: "rs", install will be skipped as a result.
Skipped: InstallRSAction.22
Skipped: Action "InstallRSAction.22" was not run.  Information reported during analysis:
No install request found for package: "bcRedist", referred by package: "rs", install will be skipped as a result.
Skipped: InstallSqlAction
Skipped: Action "InstallSqlAction" was not run.  Information reported during analysis:
No install request found for package: "sql", install will be skipped as a result.
Skipped: InstallSqlAction.11
Skipped: Action "InstallSqlAction.11" was not run.  Information reported during analysis:
No install request found for package: "sqlsupport", referred by package: "sql", install will be skipped as a result.
Skipped: InstallSqlAction.12
Skipped: Action "InstallSqlAction.12" was not run.  Information reported during analysis:
No install request found for package: "sqlncli", referred by package: "sql", install will be skipped as a result.
Skipped: InstallSqlAction.18
Skipped: Action "InstallSqlAction.18" was not run.  Information reported during analysis:
No install request found for package: "owc11", referred by package: "sql", install will be skipped as a result.
Skipped: InstallSqlAction.21
Skipped: Action "InstallSqlAction.21" was not run.  Information reported during analysis:
No install request found for package: "sqlwriter", referred by package: "sql", install will be skipped as a result.
Skipped: InstallSqlAction.22
Skipped: Action "InstallSqlAction.22" was not run.  Information reported during analysis:
No install request found for package: "bcRedist", referred by package: "sql", install will be skipped as a result.
Skipped: InstallSqlAction.9
Skipped: Action "InstallSqlAction.9" was not run.  Information reported during analysis:
No install request found for package: "msxml6", referred by package: "sql", install will be skipped as a result.
Skipped: Action "InstallASAction" was not run.  Information reported during analysis:
No install request found for package: "as", install will be skipped as a result.
Running: InstallNSAction.10 at: 2008/6/15 12:20:49
Installing: sqlxml4 on target: SERVERNAME
Complete: InstallNSAction.10 at: 2008/6/15 12:20:52, returned true
Skipped: Action "InstallRSAction" was not run.  Information reported during analysis:
No install request found for package: "rs", install will be skipped as a result.
Skipped: RepairForBackwardsCompatRedistAction
Skipped: Action "RepairForBackwardsCompatRedistAction" was not run.  Information reported during analysis:
No install request found for package: "bcRedist", install will be skipped as a result.
Skipped: UninstallForMSDE2000Action
Skipped: Action "UninstallForMSDE2000Action" was not run.  Information reported during analysis:
Action: "UninstallForMSDE2000Action" will be skipped due to the following condition:
Condition "Action: InstallSqlAction was skipped." returned true.
Skipped: UninstallForSQLAction
Skipped: Action "UninstallForSQLAction" was not run.  Information reported during analysis:
Action: "UninstallForSQLAction" will be skipped due to the following condition:
Running: InstallNSAction at: 2008/6/15 12:20:52
Installing: ns on target: SERVERNAME
******* Got commit request from MSI *******
Complete: InstallNSAction at: 2008/6/15 12:21:24, returned true
Skipped: UninstallForRS2000Action
Skipped: Action "UninstallForRS2000Action" was not run.  Information reported during analysis:
Action: "UninstallForRS2000Action" will be skipped due to the following condition:
Condition "Action: InstallRSAction was skipped." returned true.
Running: InstallToolsAction.10 at: 2008/6/15 12:21:25
Error: Action "InstallToolsAction.10" threw an exception during execution.  Error information reported during run:
Target collection includes the local machine.
Fatal Exception caught while installing package: "10"
        Error Code: 0x80070002 (2)
Windows Error Text: The system cannot find the file specified.  Source File Name: sqlchaining\sqlprereqpackagemutator.cpp
Compiler Timestamp: Tue Aug  9 01:14:20 2005
     Function Name: sqls::SqlPreReqPackageMutator::modifyRequest
Source Line Number: 196
---- Context -----------------------------------------------
sqls::InstallPackageAction::perform
WinException caught while installing package. : 1603
        Error Code: 0x80070643 (1603)
Windows Error Text: Fatal error during installation.  Source File Name: packageengine\installpackageaction.cpp
Compiler Timestamp: Fri Jul  1 01:28:25 2005
     Function Name: sqls::InstallPackageAction::perform
Source Line Number: 167
Error: Failed to add file :"C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0002_SERVERNAME_.NET Framework 2.0.log" to cab file : "C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\SqlSetup0002.cab" Error Code : 2
Error: Failed to add file :"C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0002_SERVERNAME_.NET Framework 2.0 LangPack.log" to cab file : "C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\SqlSetup0002.cab" Error Code : 2
Error: Failed to add file :"C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0002_SERVERNAME_.NET Framework Upgrade Advisor.log" to cab file : "C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\SqlSetup0002.cab" Error Code : 2
Error: Failed to add file :"C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0002_SERVERNAME_.NET Framework Upgrade Advisor LangPack.log" to cab file : "C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\SqlSetup0002.cab" Error Code : 2
Error: Failed to add file :"C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0002_SERVERNAME_.NET Framework Windows Installer.log" to cab file : "C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\SqlSetup0002.cab" Error Code : 2
Error: Failed to add file :"C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Files\SQLSetup0002_SERVERNAME_.NET Framework Windows Installer LangPack.log" to cab file : "C:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\SqlSetup0002.cab" Error Code : 2
Running: UploadDrWatsonLogAction at: 2008/6/15 12:22:51
Message pump returning: 1603
