SQL Statement help
Capodecina
Permabanned
31 Dec 2003
Barrow-In-Furness
Can't figure out this SQL statement, two tables..
tblCodes
CodeID
CodeCategory
tblHours
TimeCode
blah
blah
blah
blah
Trying to SELECT all fields from tblHours where the CodeCategory = @SelectedCodeCategory
Been messing for a little but I just can't get anything working. Can anyone help?
select *
from tblHours, tblCodes
where tblHours.CodeCategory = tblCodes.CodeCategory
and tblCodes.CodeCategory = :value
Or
select * from tblHours
where tblHours.CodeCategory = (select CodeCategory from tblCodes where CodeCategory = :value);
Both the above should work in Oracle
SELECT * from tblHours
JOIN tblCodes
ON tblHours.TimeCode = tblCodes.CodeID
WHERE tblCodes.CodeCategory = @SelectedCodeCategory
This is on the assumption that the TimeCode column on the Hours table relates to the CodeID column on the Codes table.
JOIN tblCodes
Cheers, yes TimeCode does relate to CodeID :)
How do I limit the fields from tblCodes, I only need CodeCategory really...
