SQL stored procedure variable not being set
6 Oct 2008
Hi folks,
Hope someone can help me with this.
I need to get monthly figures out of our database and create a report.
I have created a stored procedure to get this information, but when debugging in visual studio I find that one of the variables isn't being popuated.
Here is the procedure:
Code:
BEGIN
	DECLARE @extract_dates nvarchar(64), @month nvarchar(64), @extract_date nvarchar(64)
    -- Insert statements for procedure here
	DECLARE app_cursor CURSOR FOR
		SELECT DISTINCT TOP (100) PERCENT { fn MONTHNAME(EntryDate) } AS Month, MAX(EntryDate) AS ExtractDate
		FROM         dbo.Applications
		WHERE     (sqlAcYear = '2010')
		GROUP BY { fn MONTHNAME(EntryDate) }
		ORDER BY ExtractDate
	OPEN app_cursor
	FETCH NEXT FROM app_cursor INTO @month, @extract_date
	WHILE @@FETCH_STATUS = 0
	BEGIN
		SET @extract_dates = ', CONVERT(DATETIME, ''' + @extract_date + ''', 102)' + @extract_dates
	END
	CLOSE app_cursor
	DEALLOCATE app_cursor
END
	SET @extract_dates = SUBSTRING(@extract_dates, 1, LEN(@extract_dates)-1)
BEGIN
	SELECT DISTINCT TOP (100) PERCENT { fn MONTHNAME(EntryDate) } AS Month, EntryDate,
		SUM(DISTINCT sqlp + sqlack + sqlao + sqlrw + sqlrd + sqlapa + sqliq + sqldna + sqlintv + sqlna + sqlowl + sqlwdrw + sqliap + sqlconfa + sqlconfb) AS Applications
	GROUP BY EntryDate, { fn MONTHNAME(EntryDate) }
	HAVING EntryDate IN (@extract_dates)
	ORDER BY EntryDate
END
The variable in question is @extract_dates within the cursor.
Cursors are evil, I imagine that could be rewritten without them.
Does it work if you just use say:
SET @extract_dates = 'testtesttesttest' in the cursor? Is the loop evening happening (try printing something inside it and see if it shows up in the messages).
Totally agree with Pho, get rid of the cursors and use a Loop:
Set @Index=1
While @Index<100
Select @Index
Set @Index=@Index+1
End
Should be a lot easier to debug. (and a hell of a lot quicker)
Yes, the cursor is returning values.
I've discovered that it is because I can't set the variable value using itself.
I can't do:
But I can do:
I just need to figure out a way of building a string
Might be because of the null initialisation.
Try:
PHP:
DECLARE @extract_dates nvarchar(64) = '', @month nvarchar(64), @extract_date nvarchar(64)
If I do that I then get the following error:
Cannot assign a default value to a local variable.
Must declare the scalar variable @month.
Must declare the scalar variable @extract_date.
Must declare the scalar variable @extract_dates.
OK how about this instead:
PHP:
SET @extract_dates = ', CONVERT(DATETIME, ''' + @extract_date + ''', 102)' + isnull(@extract_dates,'')
