Got my car in August and all has been fine but in the past couple of weeks under braking (usually when braking medium-hard) the front drivers side squeaks. There's no squeaking unless I brake and there's no grinding or grating noise.
What would this be? Worn pad? Is it just a case of replacing the pads or will the disc need replacing as well (and if so presumably both fronts would need replacing)?
