Squeeking in low moving traffic, after wheel balancing
14 Apr 2003
Leicester
Hi all,
Could the garage who done the balancing done something when doing it, as I have an annoying squeek (not constant, probably about with every full wheel movement, up till about 15-20mph, sounds like drivers brake disk or similar)
I am guessing it needs new disks and pads now :( best online place? :p (cheap)
The squeak will be a bearing or something sticking, get the car off the ground and spin the wheel round to see where it is coming from.
As for cheap car parts, i am yet to find anyone as cheap as euro car parts.
A bearing :(, weird how it has only just happened after going in for wheel balancing :(
I am off week after next so I will have to do it then, hope it lasts lol
ECP hardly have any Vauxhall parts :(, front brake pads is about it for the calibra :(
Finally got it checked, and I got told the front brakes need 'cleaning' and the rear disks/pads need replacing!
