its hanging out the back at the moment and never got round to mounting it properly due to the sodding 92mm fan holes at the back, I have a push pull config with a pair of noctuas, anybody got any suggestions who has this setup
TBH TJ-07 is far from the best case for the H50/H70 due to the lack of a suitable 120mm fan spot at the rear. Would the tubing reach far enough to make up some sort of custom mount in the front of the case with a hard drive bay adaptor modified to take the fans and rad? Failing that its one fan or two very slim fans and mount it in the top in place of one of the pre fitted case fans.
Personally I would suggest selling the H50 and getting some more 'Bespoke' water cooling which is what the TJ-07 excels at!
