SSD Advice
27 Jan 2006
Newcastle
Hi,
I have an Asus Rampage II Extreme Intel X58 , love the Mobo btw.:D
I'm using a raptor as my o/s hard drive,
I'm using Vista 64 atm. and tbh been solid as a rock .
but i'm toying with the idea of a SSD, and banging Windows 7 on it.
2 questions...
1. What Improvements will I see?
2. will I need a Sata 3 adaptor or something to get best speeds out of
a good SSD.
I was looking at this Crucial RealSSD C300 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CTFDDAC128MAG-1G1) (is this any good) I know 3 questions lol
and this if needed ....
Asus U3S6 USB3.0 & SATA 6Gbps PCI-Express Controller Card [U3S6]
Thanks in advance for your advice.
You won't regret going for Crucial C300 SSD. I have just built a new system using the 64Gb version and the SSD speed is amazing, one click and an app is open. I would certainly recommend an SSD anytime.
I have same mobo as you.
I have an OCZ 3GB Sata SSD as drive C: and a Raptor as Drive D:
Also run XP and Win 7 64Bit.
Crucial SSDs are fast reading (355Mb/s), but SLOW writing (140Mb/s)unless you go for the big drives.
OCZ SSDs read (285Mb/s) and write (275Mb/s) speeds are around the same.
Biggest Improvements, are Boot times, an general speed access when running off the SSD...
You will need an adapter for Sata 6GB/s
You will NOT need an adapter for Sata 3GB/s
Its up to you...Your mobo supports Sata 3GB/s I know i run a SSD of it...
My M225 SSD recently started to die/died. Crucial sent me a C300 replacement and it is noticeably better than my old ssd so it must be a massive jump from HDD to an SSD.
