SSD and RAM advice
13 Jan 2015
Hi all,
I would appreciate your advice on upgrading my PC. I've had advice from here before on upgrading my graphics card and PSU and the recommendations have always been spot on.
I think it is (finally) time to make the jump to SSD. I am currently using about 560gb of my 1tb HDD. My motherboard has 2x SATA 6gb/s slots and 4x SATA 3gb/s
What is the best way to upgrade, a single large SSD, a smaller SSD and an external HDD or 2 smaller SSDs? What product do you recommend?
My other question was regarding RAM, I was thinking of upgrading to 2x 8gb ddr3 and was looking at the ones below, will this make a difference to my performance or better to wait until some point in the future when I get a new motherboard/processor (probably in a couple of years). My motherboard has 2x DDR3 slots
https://www.overclockers.co.uk/king...ual-channel-kit-hx318c9srk2-16-my-207-ks.html
Finally, if you think there is a better way to upgrade than SSD or RAM, I'd appreciate your thoughts
My build:
Processor (CPU) Intel® Core™i5-2500k Quad Core (3.30GHz, 6MB Cache) + HD Graphics
Motherboard ASUS® P8Z77-V LX: USB 3.0, SATA 6GBs, ATI®CrossFireX
Memory (RAM) 8GB SAMSUNG DUAL-DDR3 1333MHz (2 X 4GB)
Hard Disk 1TB 3.5" SATA-III 6GB/s HDD 7200RPM 32MB CACHE
GeForce GTX 970 TURBO OC 4096MB GDDR5 PCI-Express Graphics Card
DVD/BLU-RAY Drive 12x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW
Power Supply Superflower Leadex Gold 550W "80 Plus" Power Supply
Processor Cooling INTEL SOCKET LGA1155 STANDARD CPU COOLER
Sound Card ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO
1440p Monitor
All I can say is, wow, you've waited this long to get an SSD - it's going to feel like you have a brand new system. :D
With regards to the question, SSD's are dropping in price pretty fast, I'd grab a 480-512GB one (£70-80), then use your current drive as slow storage.
Buy the biggest SSD you can afford, preferably around the 500gb capacity. Don't get too bogged down by transfer speeds - they're all pretty similar nowadays.
8gb RAM should still be fine for most things but 16gb is the amount usually recommended here for a new gaming PC. Whether you notice a difference or not will largely depend on the games you play and programs you use.
