atomiser
atomiser
currently running a mid-2010 13" macbook pro. i make extensive use of virtual machines as i do a lot of development work, and the 13" screen when i'm on the go is a bit of a hindrance. i'm considering upgrading to the new mid-2012 15" with retina display that has just been released. do i need to be concerned about the use of virtual machines shortening the life of the ssd storage? i would be less concerned if it were standard form factor, but as it's a proprietary design connected in via a mini pci-x card any replacement of this is likely to be expensive. would this be covered by applecare if it were to fail during the term of the coverage? i know i could run the virtual machines via a usb/firewire/thunderbolt enabled caddy, but i spend a fair amount of time on public transport and this would just be a bit too clunky to be honest. thanks.
