Hi all,
Simple question, possibly a hard answer
I'm tempted by a small SSD (say 60 gig) to set up as a cache for my main 1TB hard drive - but I'm also a fan of partitions, and said drive is split into 4, which I'm very very reluctant to faff around with.
So, when using the almighty power of the Z68 chipset in this way, am I going to get stuck with only caching one partition, or is it smart enough to do all of them as a disk? Or would I be able to set up separate 20GB caches for each partition?
Cheers!
Cheers!
