- 4 Jul 2006
Back to mechanica 80GB Drive due to serious SSD Issues.
Over the span of 3 days I went from BSOD's to not even being able to boot up with out Fatal Error message with no text and unable to right click without system throwing hissy fit and the SSD Write Speed dropping to around 8mb/s to getting errors when trying to install windows onto the drive itself (Wouldnt even get past the part where it showed the partitions, wouldnt let me even delete or format).
Even started to get error in event viewer that said something about I/O error and too much data at once or something.
Whack the mobo back into IDE mode from AHCI and an 80GB Mechanical Drive and ive had system up, 60-80mb/s write speed.
It was a Samsung 830 SSD 3 Years, 6 Months old and I believe the overall write was about 13.59TB.
What software do they have to test the drive because according to HDSentinel and CDM the drive was healthy and whilst HDS reported 91% health CDM was reporting 100%.
Is it possible to install the software on a non samsung drive in order to perform a check on a Samsung drive ?
I have looked on Samsung site and cant see anything specific that suggests its for health checking just cloning / performance tuning and such.
