ssd help
17 Feb 2011
hi all hope you can help have a ssd drive with windows installed pc came up with blue scrren so rebooted pc pc unable to boot tryed to reinstall windows on ssd windows will not install so removed ssd from pc installed windows on another hard drive pc running fine shut down pc reconected ssd pc ran formated ssd in windows incase it was couruped or some thing tryed to reinstall windows on ssd got same problem as above again so think i need to send ssd of for rma only got it in jan so just wandering what you guys think
Long shot, have you tried turning the SATA controller from IDE to AHCI? the option is in the BIOS, then installing windows.
