Hi,
I have 2 x SSD and 1 x Blu-Ray drives.
So I removed my Blu-Ray drive SATA cable and added a HDD in its place for a temporary health check, and another HDD in a spare slot. They were at first both in spare slots but weren't showing up correctly (potentially a separate problem), and only seemed to show in the SATA slot the blu-ray is using so in the end I put them into that one by one and did the health checks.
I then removed the extra drives and powered on the PC forgetting to plug the Blu-Ray back in (seemingly irrelevant but thought I'd mention it). Anyway I noticed my SSD (the non-OS one) is no longer showing and says it need initialising before use now. Blu-Ray has since been plugged back and I've checked the connections on the SSDs.
Any idea on how this has happened (my SSD needing initialising) and how I can get it back properly without losing any data please?
I tried to initialise as GPT which didn't work as it doesn't meet the minimum size requirement, and initialise as MBR says 'The system cannot find the file specified'.
Any ideas please? Would be greatly appreciated!
Thanks!
Thanks!
