Same physical format, same.slot bit different keying. It looks like a SATA M.2 drive would fit on an NVMe compatible slot but not vice versa:Ah - I don't know. It's:
WD Blue WDS250G2B0B-00YS70
I don't see "NVMe" anywhere. Is it usable?
Would an NVMe drive have the same physical format?
In the short term, you can get adapters that turn M.SATA or M.2 into a normal 2.5" SATA drive. Usually about £5-7, so not too painful on the wallet if you don't want to return the driveThanks - I had missed the detail that there are two "almost the same" formats. I can't use this one in any of my systems at the moment. The reason I bought the adapter was that I don't have an M.2 socket.
No worries, glad it's sortedThanks again. I've ordered an M.2 to SATA adapter. With this I can use the SSD as there is a spare bay, so all I lose is an unnecessary adapter.
