SSD upgrade for Surface Laptop 4?
12 Mar 2003
USA
Hi All,
I have a Surface Laptop 4 (13.5" with the Core i7) and I am looking to upgrade the SSD, which is currently a 512GB PCI-E gen 3 drive.
I bought a WD Black SN770M 2TB (gen 4), assuming it would be easy to clone a replace the existing drive. However it seems like there are some horror stories with thin and light laptops using 10th/11th gen Intel processors and their ability to support gen 4 drives, likely due to varying power demands. Examples:
https://dancharblog.wordpress.com/2...to-1tb/#gen4-ssds-may-not-work-in-all-devices
https://answers.microsoft.com/en-us...h-pcie-4/af2c7eff-54ca-4b2c-9e0c-0ab3a274eccd
Wondering if anyone has tried doing this, and whether it has worked successfully?
Cheers,
Su
There was a few people having success on reddit. They had to change some of the power settings before cloning it if I remember correctly, I will try and find the info again.
