SSH takes a few minutes to login
Caporegime
18 Oct 2002
Back in East London
On one of my boxes, when I SSH to it, it takes a few mins to login. Even on LAN when I am sat next to it.
I think it's reverse host lookup, but I can't find anywhere to change the config. Any one know where I can find it? also any other suggestions to the slow down?
you may want to fix reverse lookup properly - other applications will bite you too.
Do you run your own DNS server? (bind/named)
we do, and we don't. The machine is currently on our network, but will eventually be "out there" with gprs modems on the public network/isp network.
We are dependent on reverse lookups for other stuff afaik, and the only issue we've had so far is with sshd. :)
