SSL Certs and SEO - Two Stores Same Server
18 Oct 2003
Midlands
An SSL certificate is generally limited to a single domain name i.e. store.####.com, so as long as you don't change the domain name you should only need one. You can get special SSL certificates that will allow all sub-domains but they can get expensive.
Yup - the one SSL will do.
If you want a cheap Positive SSL go buy an info domain from Namecheap for $3 and they give you a free SSL cert that you can use where you want.
